lower timing gear replacement
Old Sep 14, 2008 | 05:48 PM
l8nighter1's Avatar
Default lower timing gear replacement
I recieved a YFM200 free, it would not start, I fixed the carb ans it started but smoked like a desiel... I took off the head and cylinder to replace rings and change valve guides and seals... while doing the work I thought I would replace the timing gears, chain, and guides... I am down to the lower gear and it appears to be a repss fit on the shaft... anyone know if this is true? If so I am thinking of leaving it and just replacing the upper and chain since I donlt have the cases demated.
Old Feb 8, 2009 | 09:07 PM
l8nighter1's Avatar
I found out that it is mated to the crackshaft and to replace it requires the crack to come out and split into sections... I decided against it and put the enign eback together without changing it.
robj
Jun 15, 2015 08:45 PM
ROWALKER
Jun 15, 2015 05:38 PM
cornermike
May 27, 2015 10:04 PM
ragewraps
May 27, 2015 08:07 AM
Ursus
Oct 1, 2000 12:28 PM
