lights?
Old Jan 30, 2001 | 01:27 AM
real4x4's Avatar
does anyone have any extra lights on their sp500?i mounted a set of catapiller heavy equipment lights on mine with excellent results.they came with 24 volt bulbs.i put the replacement 12 volt bulbs in mine/55 watt.mounted on top of front rack they are brighter than all 3 polaris lights at the same time!anyone have seen these lights?
Old Jan 30, 2001 | 02:19 AM
keithb's Avatar
Are you referring to these lights found at this URL?
http://www.abllights.com/5x5_work_lamps/standard.html
If so, they say "CAT" on them but are made by ABL. The price of the cat ones are about $88.00 each Canadian dollars and the exact same ABL light sells for $40.95 Canadian each.Your choice in the 12 or 24V H3 bulb. You can also choose 35W, 55W, or 100W bulbs. There is also flood of spot lenses available. If you want to learn more about these lights feel free to ask, I am fairly educated in the field.
Keith
Old Jan 30, 2001 | 01:54 PM
real4x4's Avatar
thats the ones i have!they are killer lights!wonder if i could use the 100 watt bulbs without any trouble?
Old Jan 30, 2001 | 11:32 PM
D3's Avatar
D3
Hey KeithB I used to live in Prince George, I've also got a 1991 TrailBoss. Small world.
Old Jan 31, 2001 | 02:30 AM
keithb's Avatar
Hey D3, you know PG is a great place to live if you are into the outdoors eh? All the camping fishing and quading, dirt biking you can handle. Right in your back yard. I am loving it here, if ya can look past the pulp mills and all the stink that is...Ha ha.
Hey Real 4x4, if you go to the 100W bulbs you will most likely run into problems. Your alternator is only putting out a certain amount of amps and if you have too much load on that little alternator (or is it a magneto?) you can stress it and burn it out prematurely. You may already be doing damage with the 2 55W bulbs that you already have on there. Did you disable the stock polaris lighting?
Another problem with 100W bulbs is again the amp draw they need. Small guage wiring and harnesses can burn up and melt if the wire is to small to accomodate the large amp draw.
And yet one last thing...100W H3 halogen bulbs get very hot and are easily damaged and prematurely burt out due to vibration. The 55W's are more durable especially on an ATV.
If you look at the little spring resistor inside the bulb, it breaks and then nothing...no light.
If you stick with good quality H3 bulbs from companies like Hella or Sylvania or G.E. or Phillips ect..They will out last the cheap Asian made ones.
Now you know why your stock polaris only has 20 to 35W bulbs I think it is. Someone correct me if I am mistaken.
Remember learing about electricity? E=IxR or the triangle version.
Keith
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
