banshee not runing on all cylinders
Old Sep 17, 2008 | 09:58 PM
exrider91's Avatar
Default banshee not runing on all cylinders
i have an 01 banshee about a month ago wen riding it it last all its power out of nowhere and wouldnt idlei though it was that my plugs were old wen i stoped my right crab was leaking so i said ill wait 2 fix it cuz i had cool heads on their way 2 my house well after a month of sitting i finally fixed it yesterday put on the coolheads new plugs rebuilt both carbs. after i finished i started it up ran just like it did b4
i check spark both have it, it has fuel and ill check compressen this weekend i need 2 get my tester from work. wen i first tryed 2 fix this problem i checked 4 cracked boots their fine then i checked 2 c which cylinders was not @ full power the left side was working but barly the right as soon as the plug was pulled it shut off unless i had it higher then idle i fliped the plug caps 2 c if it was the coil i got the same result i gave it a quick test ride wen i stoped the right crab was leaking again so i rebuilt it about 8 more times finaly it stops now i start it and it was idleing fine 4 about a min then the rpms droped and it shut off i raised the idle and rode it again it was alot better then before but the bottom end was still realy bad i stoped and left it runing wen i got off the left side pipes was smoking but the right wasnt before they both did but the left was very little so i but my hand behind the pipes the left side is hot the right cold so i pulled the plugs again this time the right side is barly working less then the left side was doing b4 and wen the left was pulled it shut off so again i flip the caps and again the left is working the right nothing i dont get what would cause this 2 happen i need some help
Old Sep 17, 2008 | 11:00 PM
exrider91's Avatar
i was just looking around the forum and it seems that the tors mayb causing the problems is their a way 4 me 2 disconnect them 2 c if their the cause of the problems b4 i choose 2 remove them
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
