500 X2 batery repalcement PITA
Old Sep 18, 2008 | 10:12 PM
The Black Pearl's Avatar
Default 500 X2 batery repalcement PITA
I just had to replace my battery on my 2007 X2, what a PITA. No room to work at all, I must have done it the hard way. However I put on the easy connectors to a Battery Plus charger. I had never taken care of the previous battery, lessons learned $150 latter. I bought the same replacement battery I did not want to try and fit another brand in (Yuasa).
Old Sep 19, 2008 | 01:12 PM
OIown12's Avatar
I second that. The week that I got my X2, the rubber battery strap broke and the battery slid back against the exhaust. Melted a big hole in the casing. Got it covered under warrany though. I added a winch later. Dang near impossible to get to the terminal screws.
Old Sep 19, 2008 | 02:18 PM
My battery has been good. But, I run it pretty often. At least a couple times per month. I know what you are saying about the tight quarters that they put the battery in. I made the mistake of leaving my wedding ring on when I installed my Warn/Polaris winch. Contacted the positive lead, ring, to engine block. Took about an 1/8" of skin off my finger.
Old Sep 19, 2008 | 08:21 PM
<div class="FTQUOTE"><begin quote>Originally posted by: OIown12
I second that. The week that I got my X2, the rubber battery strap broke and the battery slid back against the exhaust. Melted a big hole in the casing. Got it covered under warrany though. I added a winch later. Dang near impossible to get to the terminal screws.</end quote></div>
Rubber battery strap? I have a metal bracket that clips on to the case?
The extra rings for the quick connect battery charger made this work more difficult. I had to put a screw driver under the bolt on the terminal to raise it up so the screw would reach the bolt.
Old Sep 19, 2008 | 09:35 PM
Spdecat's Avatar
I wonder why they could not of put the battery in the same location as the 500 non X2 under left rear fender . What's there preventing that location from being used ? In that location you can take one out in minutes .
Old Sep 19, 2008 | 10:00 PM
OIown12's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: The Black Pearl
The extra rings for the quick connect battery charger made this work more difficult. I had to put a screw driver under the bolt on the terminal to raise it up so the screw would reach the bolt.</end quote></div>
Yep, rubber with a D-ring at each end. I tried to get the dealership to convert it to the metal top, but they wanted me pay for it. Said they couldn't do it under the warranty.
Old Sep 20, 2008 | 09:05 PM
DOC HOLIDAY's Avatar
hey guys,the battery holddown strap on my 2007 x2 kept breaking,finalily,polaris recalled it and replaced it with a metal holddown,it works great.
suzukirider6490
May 1, 2006 12:53 AM
suzukirider6490
Apr 14, 2006 10:54 AM
SlueFoot
Mar 16, 2006 11:47 PM
DirtBurgler
Jan 19, 2006 02:40 PM
sharpie
Apr 3, 2004 01:33 AM
