Master cylinder on trailboss 250
Master cyl kits still available,BUT have posted before even with piston and seal install kit not always good luck because of worn/corroded cylinder bore,sometimes better to up grade to newer type master cylinder! Worth the cost,easier to bleed,better braking! THAT IS if you have the old RED handled brake lever version! Good luck
<div class="FTQUOTE"><begin quote>Originally posted by: yzfrcr@msn.com
I have an old trailboss with the red handled MC. I can tell its going bad. Is there a newer MC thats known to work well or will almost any of them be OK?
Thanks,</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] Yep can upgrade to part number 2050073,better master cylinder!
