Overheating
Old Sep 23, 2008 | 12:40 PM
Magnum95's Avatar
Default Overheating
I had an issue with the quad overheating. The fan wasn't turning on. Went through wiring and fixed that issue. Now its overheating again. Even with the fan running continuous. If i run it down the field the heat light goes out. I don't think is the thermosat but will check that. How do I check the waterpump and how difficult is it to R & R?
Thanks
Jeff
Old Sep 23, 2008 | 05:12 PM
02magnum500's Avatar
Gets his share of deer.
Default Overheating
Make sure your radiator is not filled with dried mud and gunk. Try clean it out with a hose if it is dirty.
Old Sep 23, 2008 | 06:02 PM
Magnum95's Avatar
Default Overheating
I've done that. The pump seems to be working but I'm wondering if its not pumping enough at slow speeds
Old Sep 25, 2008 | 01:43 AM
CaptainQuint's Avatar
Default Overheating
They seem to run a bit hot normally.
Pressure test the radiator. They're known for developing problems between the tank and the fin section.
Old Sep 25, 2008 | 09:23 AM
Kerbbirds's Avatar
Default Overheating
Did you test the thermostat?, You remove it and put in a pan of water with a thermometer, should open at 175-180.I have one of these bikes , it doesnt run hot at all, fan hardly ever comes on, must have some blockage in radiator if t-stat is ok.
Old Sep 25, 2008 | 10:29 AM
Magnum95's Avatar
Default Overheating
Rad doesn't seem to leak. I'll remove t. sat and check. Thanks Guys
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
