2000 Trailblazer 250 2 Stroke
Old Sep 23, 2008 | 02:51 PM
brianvabeach's Avatar
Default 2000 Trailblazer 250 2 Stroke
OK guys need some advise.
Have TB 250. Hotseat Pipe, Stock Carb with 150main jet, 40 pilot jet, moved needle clip to richest setting and seems like I am still running lean. Still getting flat spots or no response sometimes in mid range throttle. Should I go to larger needle jet and new needle?????
Old Sep 23, 2008 | 07:27 PM
ftwflh's Avatar
Do you have the matching HSP clutch kit for that pipe?If not you are waisting your time on messing with the carb and stand a good chance of messing up your motor.
Old Sep 23, 2008 | 09:01 PM
Dont even know. Just bought it about 3 weeks ago. Ran decent but not great for about 1 days riding then the floats stuck and flooded out the system. Pulled carb and cleaned it, checked float adjustment. Took me about a week and a half just to find out where the exhaust came from. finally found the look alike on HSP site.
Old Sep 23, 2008 | 10:18 PM
ftwflh's Avatar
Take you a cold compresion reading too.
Old Sep 23, 2008 | 10:58 PM
OK thanks. ALso. I need to replace the Bushing on the bottom of steering shaft. It is riveted in. What is used to hold in replacement????
Old Sep 23, 2008 | 11:05 PM
ftwflh's Avatar
The HPD kit comes with bolts
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
