web 109 cams make the valves slap stock piston?
Old Sep 24, 2008 | 06:49 PM
bigbird650's Avatar
Default web 109 cams make the valves slap stock piston?
i have herd the web 109 cams would make the valves slap the stock piston is that true?
Old Sep 24, 2008 | 09:08 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
I don't think so
Old Sep 24, 2008 | 09:22 PM
TheStir's Avatar
Started riding ATVs in 1974!
Only if you were to float the valves I guess, there are a lot of people running them with stock valves. Not sure if you need a shim under for it though.
Old Sep 25, 2008 | 06:28 PM
DragonDJ11's Avatar
There is no way they should with proper set up. You need to be shimmed to the proper valve clearance, and be sure the timing is set up correctly. And all of that should be done with the Piston at Top Dead Center
Old Sep 26, 2008 | 07:02 PM
MRDS650's Avatar
Canadian and Proud of it !!!
I 2nd Dragon - as long as the valve lash and timing are set right - there should not be a problem.
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
