SPEEDO AND AWD DOES NOT WORK
Old Sep 26, 2008 | 10:14 PM
2005 NH POLARIS 700's Avatar
Default SPEEDO AND AWD DOES NOT WORK
i HAVE A 05 SPORTSMAN 700EFI, THE SPEEDO FADES IN AND OUT, ON FOR 20 SECONDS, OUT FOR THE REST OF THE DAY. i KNOW AWD WILL NOT WORK WITH THE SPEEDO NOT WORKING. ANYTHING I CAN DO WITHOUT BUYING A NEW SPEEDO?
Old Sep 26, 2008 | 10:24 PM
Check speedo wiring under pod where it ties to main harness. Had a 500 last week had same symptoms,ended up being wiring zip tied too tight,causing intermitent short to speedo.
Old Sep 26, 2008 | 10:34 PM
THANK YOU.
ALSO i FORGOT TO MENTION. THE SPEEDO HAD/HAS A LOT OF MOISTURE UNDER THE GLASS.
WHAT DO YOU MEEN BY "UNDER THE POD"?
Old Sep 26, 2008 | 10:41 PM
Moisture could be the problem then! Some poster have used hair dryers to remove moisture,some others have torn into their speedos! Should get more suggestions from other members! When I said "under pod" means take the 3 screws out on upper platic piece where speedo is,will separate from bottom "lower pod". Good luck hope you can solve your problem without a new speedo!
Old Sep 29, 2008 | 08:55 PM
Thanks for everyone's help. I took the speedo off and apart. there was some moisture and corrosion biuldup on the circut board. I removed the corosion with some scotchgaurd and used a blowdryer to dry everything off. I put it all back together and everything lit up and worked properly. saved me $300 for a new speedo.
THANKS AGAIN
Old Sep 29, 2008 | 09:06 PM
DODGE57HEMI's Avatar
Mopar Man!
I had the same problem on mine ended up being a loose ground wire unde fron cover by the radiator (brown with black stripe I think) made a whole new ground posistion has worked fine ever since!
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
