2005 Ranger 500
Old Sep 28, 2008 | 12:20 PM
Ranger_Ollie's Avatar
Default 2005 Ranger 500
Uh-Oh. Out yesterday, first I lost a CV Joint, I'm wondering what that's going to cost, and then the tranny messes up. I can switch from H to L no problem, but Neutral or reverse, no way. I pulled the cable off the side of the transmission to see if I could move the lever manually, no way. Anybody have any idea what that might be?
Old Sep 28, 2008 | 08:05 PM
Probable internal trans damage if cant shift lever by hand. Cost depends on whether you or dealer does the repair! parts usually involve shift forks,slider gears,silent chain.Parts can be over couple hundred bucks,depending upon damage PLUS labor! Most shop labor between $65-$90 an hr! Depends on shop,but can be between 5-8 hrs usually. Can get by with just cv and boot kit or may need complete assembly? Cv about $180 I think plus about $30 on boot kit. Maybe other members have aftermarket sources on parts. Good luck. let us know
Old Sep 29, 2008 | 09:55 PM
Woo hoo. I tokk the side panel apart, found out it's just the sector gear. 11 bucks for the gear and an hour of my time.
Thanks anyway!
Old Sep 30, 2008 | 10:44 PM
LUCKY!! most Have more problems than that. Good luck
Old Sep 30, 2008 | 10:51 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
What the Heck is a Sector Gear?
Is that just the part behind wherethe linkage is attached too??
.....Caper.......
Old Oct 1, 2008 | 11:16 PM
Sector gear right behind small plate along with trans detent lever where shaft comes through case that belcrank is on. belcrank hooks to shifter cable.
salixair
Nov 3, 2015 08:25 AM
WilliamBos
Sep 22, 2015 04:07 PM
greg74
Sep 10, 2015 07:58 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
