2000 Expedition 425 4x4 Head Light Bulbs.
Old Sep 22, 2008 | 11:46 PM
bbrett's Avatar
Default 2000 Expedition 425 4x4 Head Light Bulbs.
As you can see by the post count, I'm a FNG.
I've been reading & lurking, and have used the search feature.
I'm not wanting to beat a dead horse, but I need some input.
Does anyone know what the wattage is for these bulbs? (these are dual filement-high/low)
I have a nice set of 55 watt lights that will fit nicely, but I don't want to cook the alternator.
After searching & coming up with several bulb numbers, I'm still at a loss for an after market replacement. All of the suggested numbers that I have found are not a fit for this rig. The dealer gets $35.00 each for these. I'm not thrilled with spending $70.00 plus tax for these little bitty bulbs. I could lose the bulb in my ear!
Yes... I know it is a part of the snap in unit, but I haven't had any luck with that either.
Here's the number for the "unit":
81425
349A
The number on the little bulb is:
E1307
with 333 above it.
If it matters, the bulb has these numbers molded in it:
E9
I've searched McMaster & Grainger & the Al Gore Web & Here.......
I am NOT overly skilled at the 'net or computers, so I have very possibly missed something.
If someone knows the wattage or a simple "cheap" replacement, that would be great.
Thanks for looking (and groaning & laughing)
Brett
Old Sep 24, 2008 | 11:12 PM
Check your neighborhood auto supply,should be able to help,plus cost should be lower!
Old Oct 1, 2008 | 05:03 PM
bbrett's Avatar
Thanks for the reply.
I took your advice & wore out the auto parts stores. I actually had a manager at O'reily spend a ton of time trying to cross numbers & find something that would work.
Long story short... no luck at all for this particular bulb.
I'b be thrilled to know the wattage of the factory bulb, so I can wire something new in without smoking the alternator.
Old Oct 1, 2008 | 07:57 PM
dusty's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: bbrett
I'b be thrilled to know the wattage of the factory bulb, so I can wire something new in without smoking the alternator.</end quote></div>
30/30. I don't think you will be able to find a substitute.
Brian
Old Oct 1, 2008 | 11:24 PM
ftwflh's Avatar
Take the bulbs with you when you try to interchane.
bzdok1234
30
Feb 23, 2016 01:55 PM
ScopeZ_
Jul 28, 2015 01:44 AM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
