Question from a newbie
Old Sep 29, 2008 | 08:43 PM
More D's Avatar
Default Question from a newbie
We went down to the dealer and he sold us the four oils. The front, rear, motor and the 'transfercase' oils. Plus the air and oil filters.
We cant figure out where how to change the transfer case oil on the '08 Sportsman 700 X2. We just did the 25hr service on a Ranger XT and that sure had one. We just can't find the transfer case on the Sportsman.
Did the dealer sell us something we didn't need??
thanks in advance...
More D
Old Sep 29, 2008 | 11:58 PM
plumbob's Avatar
There are only 3 oils to change on an X2.The front diff,motor, and transmission.
Old Sep 30, 2008 | 12:47 AM
GrayGore's Avatar
Aren't there 2 oils in the front diff? ADC and LT?
Old Sep 30, 2008 | 07:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you dont have to change all the lubes on the first service unless you want too. if theres no rear end fluid then what do you use. READ YOUR MANUAL and see what it says and ill tell you where the drain plugs are. on models w/ adc you use prem. LT fluid and there is a seprate oil for the adc.
Old Sep 30, 2008 | 09:16 AM
I agree with Stendori. I think there is a front gearcase, transmission, engine, and rear gearcase. But mine is a 500 X2 so I can't be 100% sure on yours.
Old Sep 30, 2008 | 10:45 AM
wilburg321's Avatar
Make sure (double check) that you have the LT oil for the front end. The ADC need the LT oil (Check your owners manual) Many dealers screw this up. The regular front diff oilo can destroy the ADC. Also, check your air filter before you replace it, it should still be clean.
I have a 500 X2 and only had three oils to change on the 25 hours. The engine oil, the transmission (rear) and the the front Diff (LT oil).
I am a newbie and found this to be very easy (thanks to this forum)
Old Sep 30, 2008 | 04:45 PM
tripleR's Avatar
Just be sure your manual is up to date, my 2005 Polaris Sportsman 700 manual was wrong as to how far to fill the rear differential and there was an insert in the paperwork not in the manual showing how to make a "tool" (bent wire" to check the level and to show the proper fill level.
Hack714
Oct 6, 2015 06:51 AM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
that1redhead
Sep 8, 2015 11:47 AM
