300 bayou want start with starter?
Old Sep 30, 2008 | 11:20 PM
medicman's Avatar
Default 300 bayou want start with starter?
hey folks my 300 bayou when i try and start it with the electric start all it does is turns that is the starter but the enginge want turn over. what do you suppose it might be? thanks, wendell.
Old Sep 30, 2008 | 11:53 PM
maybe_brad's Avatar
is it getting enough juice from the battery? try hooking it up to a charger and see if it turns it over than. also will it start by the pull starter?
Old Oct 1, 2008 | 02:17 AM
Hayashi's Avatar
Sounds like broken starter gear or limiter gear since starter motor is turning but not the engine.
Old Oct 1, 2008 | 09:53 AM
bigpig750's Avatar
If the starter is turning at what seems to be full speed, then its the Bendix in the starter not engaging the starter gear to the flywheel. If the starter is not turning at full speed then It may not be getting enough power. Check all connections for corrosion, white or green build up on the connections. Also check your battery's voltage output. This will also effect your starters performance. If you do find build up on any of the terminals use a solution of baking soda and water.
Old Oct 1, 2008 | 05:00 PM
Hayashi's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: bigpig750
then its the Bendix in the starter not engaging the starter gear to the flywheel</end quote></div>
The 300 doesn't have a typical Bendix. Instead it's got that round ring that acts sort of like one-way clutch (which rarely ever goes bad due to its much more simple design than Bendix) and it works in conjunction with the limiter gear which slips at certain (excessive) torque (in case of kick back) to prevent starter/flywheel gear breakge.
Old Oct 1, 2008 | 05:49 PM
smk8er's Avatar
I had the same problem and the starter motor gear that attaches to the splined shaft on the starter is bad. I took the gear off the starter and found out it comes apart. I welded the parts together and it works like a charm.
tiresharkdbb
Sep 3, 2017 02:06 AM
clsharky
Jun 8, 2015 11:38 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
momofo
May 27, 2015 12:06 PM
