grizzley 600 wont start
Old Oct 2, 2008 | 11:47 PM
roadhazzard's Avatar
Default grizzley 600 wont start
first off I cant seem to find out too much about this wheeler, it is a 600 4x4 grizzley....I am un sure of year(altho I am told it was only made for a few years)I am wanting to say either a 98 or 99 model year.
here is my question .... it turns over easliy,sounds like it has either low compression or timing is off.
when i try to start it it will back fire thru the exhaust and sometimes thru carb.
I am trying to figure out timing specs and valve lash ..as well compression ratings , I am a avid gear head so working on the atv seems pretty easy off so far.
I just need any ideas on it or maybe some place I can get some specs from
so please any one that can help let me know ...thanks
Old Oct 4, 2008 | 12:45 AM
HeftyLefty's Avatar
Go to www. yamahausa.com and set up your owner profile. You can find an online manual there along with specs for your bike. Once you input the VIN#, it should tell you Model# and year of manufacture.
Good Luck.
Old Oct 4, 2008 | 05:42 AM
hey thanks so much , I am gonna check it out asap..!!
I will keep yha informed as it goes if thats ok man..
Old Oct 4, 2008 | 09:35 PM
HeftyLefty's Avatar
Let us know how it goes.
Old Oct 5, 2008 | 01:01 PM
thanks for the link ,that was helpfull.
well I was still unable to get a running quad so I rolled up the ol sleeves slapped on some elbo grease and tore in to it.
Upon removing the upper part of the head to further inspect the valve faces, I noticed something odd........
the piston....on the rear of it is a silver discoloration and some well not so nice grooves in it..[img]i/expressions/face-icon-small-sad.gif[/img]
here is the odd ball....you can make the piston rock front to back about an 8'th ofor less. I mean like its rockin like you have the piston and rod in your hand and the piston rocks on the wrist pin....
W.. T... F....
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
