Pure Sport Bandits vs. Razrs???
Old Jan 31, 2001 | 01:43 PM
Xplor's Avatar
I am still undecided for my new tires. I really had my mind set on some 20" and 21" Razrs for my Scrambler 4x4. But upon looking at the tread pattern and the ground clearance I would loose(1") I was thinking of the Bandits. They seem to be more aggressive and the front tires have some diagonal lugs..thus helping out the 4x4. The Razrs I have up front now carve great but have no forward pull in mud. I am used to running Bearclaws in the back so I don't want to end up with no mud traction at all.
Anybody run the Bandits? Are the front stiff enough to avoid sidewall flex and still carve good? How do the rears do? Weight?
Thanks again guys! I will make a decision one of these days...
Old Jan 31, 2001 | 07:16 PM
H300F's Avatar
I would get Razrs (20") for the rear and something more aggressive for the front. I would consider getting Titan 489s, Dirtdevils, or something along those lines - aggresive but still an "all-terrain" tire. I think that kind of setup would work great.
Old Feb 1, 2001 | 12:55 PM
snowshark's Avatar
Xplor,
Bandits are a very good tire. They are a cross between a mud tire & sport tire. They have a nice aggressive tire so you ride in mud, snow, & anything else with good to excellent traction. One note our 20" tires are taller than advertised.
Old Feb 2, 2001 | 12:14 PM
Zorro's Avatar
You're changing rear AND front again???? You're gonna get rid of your front Razrs???
Old Feb 2, 2001 | 01:24 PM
ralph2000's Avatar
bandits hook up better than almost any tire on the market besides holeshots on mx tracks. It also depends on you sprocket size, you might want to run 18" for more acceleration( bottom end)
ralph2000's Avatar
Old Feb 2, 2001 | 08:12 PM
Xplor's Avatar
You bet Zorro. Going smaller to be able to corner better and get more wheelspin to finally make it up that sand hill at St-Alexis!!!
Coming soon to a trail near you: Scrambler on steroids!
Old Feb 3, 2001 | 12:05 AM
KevinDevitt's Avatar
Hey Xplor:
I made some calls today. It seems that Douglas makes some rims that will make the front 2" wider on both sides. I can get backs that will make it 1 or 2 inches wide. Do you think 4" wider on the front would be a good idea or not? If so what about the rear 1 or 2? They did not have 1" wider for the fronts.
KD
Old Feb 3, 2001 | 12:20 AM
Xplor's Avatar
Kevin, If it were up to me I would go no farthur than 1" per side up front. I have seen numerous posts about tires "pushing" in corners if too wide. Plus I also hear they can "jarr" the handle bars when hitting an obstacle because of the extended leverage on the wheels. But take it for what it's worth because I am by far not an expert. As for the rear I may go 2 inches on each side maybe...it all depends on the tire you are running. My present tires are already wider than stock but if I get the Razrs, I will loose an inch off what I have now.
I spoke with Douglas directly for a good 30 minutes and they had nothing to make the rear end wider...unless you are planning on getting 10" rims in the back? That may be it.. If not, tell me what you know.
Plus I remember you asking about T-9 rims from ITP. If I am not mistaken aren't they the .190's but the improved version they have out this past year. Stronger and more reliable than there last model???
Sep 30, 2015 01:37 AM
cboler9
Sep 24, 2015 08:35 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
