loss of power
Old Oct 11, 2008 | 02:06 PM
spade78's Avatar
Default loss of power
I am trying to find out why my 06 hawkeye dies off at a mid range speed (about 23 mph). I have tried a number of things that I have read in these forums, but nothing seems to work. The only thing that I have found so far is that by cutting the air flow it seems to run better. Any help on this would be great.
Old Oct 11, 2008 | 03:42 PM
eggenz7's Avatar
sounds like your jets are way too big in the carb maybe flooding it out. have you recently changed airfilters or messed with the main jets
Old Oct 12, 2008 | 01:25 AM
spade78's Avatar
put a moose filter on but nothing with the jets
Old Oct 12, 2008 | 01:28 AM
eggenz7's Avatar
you might have to put a bigger jet in it.. mayby somebody that has the know how of what jet you need will chime in
Old Oct 12, 2008 | 02:12 AM
spade78's Avatar
hope so, thanx for the info
Old Oct 12, 2008 | 08:57 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
has the updates been done to it? i know they had some issues w/ the 06' hawkeye in the carbration in the mountains. pull the plug out to see how it loos. rich/lean
Old Oct 13, 2008 | 08:40 PM
spade78's Avatar
Im not sure about the updates, I got it second hand. I bought a new plug and did the oil change. The old plug was slightly carboned but nothing out of the ordinary.
Old Oct 13, 2008 | 10:16 PM
NoJoke's Avatar
I've heard of the airbox....may not have enough breather holes or they are too small. My bud's Hawkeye did this and no problem after the airbox mod. There may be some rubber plugs you can pop out and try. Maybe....
Old Oct 13, 2008 | 11:36 PM
spade78's Avatar
more air seems to make it run bad, if I cut the air back it seems to run better, good idea though. I will see if there are any rubber plugs that come out and see if that helps. thnx
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Minimod
Sep 10, 2015 08:03 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
