running problem
Old Oct 13, 2008 | 09:05 PM
EABROWN45662's Avatar
Default running problem
i have a 2003 polaris 330 magnum that if its jumped it will start and run but aftewr removing the the jumper cables it will die and not restart till jumped again please help
thank you phillip
Old Oct 13, 2008 | 09:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
so another words the battery is dead and the charging system isnt putting out any volts by the sound of it and most of the newer bikes need a 12 volt charge to stay running. take a volt tester to seehow any volts the bike is putting out off and then w/ it running. off should be be around 12.5 and running should be 13.5+ volts when around 3,000 rmps. if not then maybe the recifier is gone bad or even unplugged.
wildbill59
Jun 9, 2015 02:28 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
blaze_master
May 26, 2015 11:18 AM
