400 scrambler 4x4
Old Oct 17, 2008 | 04:03 PM
400ex.w.f.o.'s Avatar
Default 400 scrambler 4x4
I WAS LOOKING AT PURCHASING A USED SCRAMBLER 400 [2 STROKE] 4X4 AND WAS JUST LOOKING FOR ANY INFO THAT ANYONE HAD ON THESE BIKES. THANKS.
Old Oct 17, 2008 | 09:48 PM
ftwflh's Avatar
Be ready to do a topend and replace the piston and bore it out.You pipe and clutch it it will smoke your 400EX
Old Oct 18, 2008 | 12:58 AM
WHICH IS THE BEST EXHAUST FOR IT? HOW MUCH DO THE CLUTCH KIT COST
Old Oct 18, 2008 | 08:59 AM
ftwflh's Avatar
Depending on where and how you ride and what gains you are wanting here are my recommendations
Tight trails and low speed ridding-Dynoport pipe with a Dalton blk/white primary spring,Aaen blue secondary spring set 2-2 and stock weights.
Fast trails-HPD Trail pipe and matching clutch kit or Aaen Topend pipe and matching clutch kit
Best $$$ deal-RcR stage1 kit
Pipe and silencer will run $250-$350,silencers $50-$150,clutch kits around $100 and clutching is a MUST when changing pipe except for the Dynoport
Old Oct 18, 2008 | 02:56 PM
trailblazer_02's Avatar
just go with an RCR stage one kit ad get him to replace his pipe with an HPD pipe, it will run you 345$ for everything. the kit even includes clutching.
Old Oct 18, 2008 | 06:21 PM
ftwflh's Avatar
RcR kit is great but I have a fond spot for the Dynoport because you can run it with a low engagment speed
Old Oct 19, 2008 | 10:51 PM
i went to dynoports site and their TB pipe only gives like 4hp gain, whereas the hpd gives 7-8.
Old Oct 19, 2008 | 10:56 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: trailblazer_02
i went to dynoports site and their TB pipe only gives like 4hp gain, whereas the hpd gives 7-8.</end quote></div>
I have ridden both and the Dynoport comes on in the low/mid range and pulls hard to top.The HPD has a higher engagment rpm and hits hard in the mid/top end range.Depending on how you ride both are good systems with decent power gains but at dif points.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
