1999 POLARIS 400 SPORT QUESTION-having an issue and i know nothing about it...HELP
Old Oct 17, 2008 | 04:53 PM
DBOSWAN's Avatar
Default 1999 POLARIS 400 SPORT QUESTION-having an issue and i know nothing about it...HELP
Ok, so I'm in a dilemma. i purchased this atv this past weekend and before i loaded it up in the truck we drove it around and everything ran good on it, except when you came to a stop and took your finger off the gas then it would die. well i drove home with it and the next morning we took it off the truck and it cranked up and i rode it for a little while and it ran good then. well it sat up for a few days and when i went to go crank it yesterday, it didn't do anything. the guy i purchased it from was having issues with the starter, but even with the pull start, it would turn over maybe 1 out of 15 cranks but wouldn't stay on. when the seller was loading into his truck, he broke the choke switch with it on. so because i know nothing, i'm hoping someone could give me a possible diagnosis with what possibilities could be wrong with it. thanks for the long read and also thanks for any responses!
Old Oct 17, 2008 | 07:23 PM
eggenz7's Avatar
is the choke switch on now? if so, it could be running a little rich. need to get that addressed asap. another thing to check for are air leaks. take some carb cleaner and spray around all gaskets, boots, and seals while the motor is running. if you can notice an increase in RPM's there is a culprit. if the bike has been sitting for a season or two i would take the carb apart and give it a thorough cleaning and make sure everything is the way it should be. the first thing to do tho is get on ebay and buy a manual for this beast. will save you alot of headaches down the road.
Old Oct 17, 2008 | 07:31 PM
DBOSWAN's Avatar
when the switch broke, it was on the previous owner told me. thanks for the tips...
Old Oct 17, 2008 | 09:47 PM
ftwflh's Avatar
I would bet it needs a topend.do a compresion check.It needs to be at least 100PSI to start good
Old Oct 19, 2008 | 10:49 PM
DBOSWAN's Avatar
how would i do a compression check?
Old Oct 19, 2008 | 10:58 PM
ftwflh's Avatar
Screw in as compresion gauge int he spark plug hole,hold throttle wide open turn engine over check readings must be over 100psi
eggenz7's Avatar
buy a compression tester
Old Oct 19, 2008 | 11:24 PM
DBOSWAN's Avatar
how much would one of those be and where would i get one from?
Old Oct 20, 2008 | 12:00 AM
mkgearhead's Avatar
You can go to Autozone. they have a loan-a-tool service. You just pay a deposit and you get it back whan you return it.
Old Oct 20, 2008 | 12:21 AM
eggenz7's Avatar
should be atleast 100psi but tip top shape is around 120-130psi.
