1998 450S Front Differential/Shaft Problem
I have the the entire differential and two front shafts out of the machine, but there is no way I can get the shafts to pull out of the differential case.
I have pryed it, heated it, hammered it and sledge hammered it.
I've tried to unbolt the entire diff case and pry from there, but no luck.
Any suggestions. Yes, it's very muddy in there, the shaft seal is totally compromised.
Thanks
Thanks
THE ONLY THING THAT HOLDS THE SHAFTS IN THE DIFF IS C CLIPS ON THE END OF THE AXEL SHAFTS. THEY SHOULD TAP OUT WITH EASE. YOU MAY NEED TO TAKE IT TO A HONDA DEALER IF YOU ARE HAVING THAT MUCH TROUBLE WITH IT.
DTroyer01
Jul 3, 2015 07:34 AM
