blaster wont spark
Old Oct 18, 2008 | 06:46 PM
stageIVbanshee's Avatar
Default blaster wont spark
it s 95 blaster and it wont spark. is there a common problem that makes it so it doesnt spark? do you think the TORS would be causing it? help appreciated.
it could be the ignition module or the coil and if it is how do you test them because i dont have a manual.
could the stator be messed up?
Old Oct 19, 2008 | 10:43 AM
cadillacdude1975's Avatar
any of those would cause a no spark condition. start off by checking all connections and using a new plug.
Old Oct 19, 2008 | 07:30 PM
i cheked all the connectors and they all look fine. i bought an ignition module and its on its way here.so i will test it when it gets here. he said he had to floor it all the way to shift from third to fourth, would that cause it to burn out?he also said it kept bogging when you started out to move. the coil is fine i tested it. not sure about the TORS though. i unplugged the main brain and it still didnt spark.
Old Nov 2, 2008 | 11:20 PM
mojojojo56's Avatar
i dont think TORS makes it not spark, and unplugging the module wouldnt help even if it did. i cant tell you what it is though. check the stator, too sometimes water gets in there... or so i hear.
Old Nov 3, 2008 | 07:09 PM
stator and flywheel are brand new. dont know what to point to now
Old Nov 5, 2008 | 06:08 PM
hotblooded's Avatar
It wouldn't hurt to check the ignition switch, I have heard of these going out. I would also check the ground wire as well. Nothing worse than an electrical gremlin YUK
Old Nov 17, 2008 | 10:55 PM
270quadsportguy's Avatar
or the keyway in the flywheel, i had issues with that before and long and behold .99 cent part
Old Nov 18, 2008 | 04:45 PM
91Warrior357's Avatar
yea the keyways cause probs also, just for the heck of it unplug the key switch and see if it sparks.
Old Nov 19, 2008 | 09:27 PM
one time when doin a blaster i forgot to hook up a wire to the throttle for tors and it wouldnt spark either,once i pluggd it in it was good. I have 4 or 5 cdi boxes layin round
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
