Front Driveline Problem
Old Oct 19, 2008 | 09:14 AM
sportman400's Avatar
Default Front Driveline Problem
Has anyone ever had a front driveshaft yoke get extremely loose on the front pinion shaft that comes out of diff? Last week I jumped my 06' 500 (way too high)and now the front yoke and both front axles have alot of slop in them at the cv cups where axles go into the diff. and ther is a slight clunk sound when I ride which seems to be coming from front end. AWD still works. I have checked a few other used Sportmans at dealers which all had more miles than mine and the drivlines were all tight ....like mine was a few weeks before this happened. Any ideas?
Old Oct 19, 2008 | 01:42 PM
MECHANIKE's Avatar
i have the same thing,sport,i've had it for years.mine is tight PARELLEL with the roll pin,i'f your moving the yoke up and down when the roll pin is horizontal its acting like a hinge and mine has been loose for e'ons..........don't care.
Old Oct 19, 2008 | 05:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
any oil leakage? maybe bearing got damaged?? hard to tell, but if the case isnt cracked thats a good thing.
Old Oct 19, 2008 | 11:09 PM
No oil leaks from any of the seals and no cracked case. Don't really know what's wrong. Won't be going on any big rides till at least I find what's causing the slight clunk sound.
Old Oct 20, 2008 | 12:00 AM
Indslpwr04's Avatar
I have seen yokes loose like that from the factory. We 4 scramblers with in my circle and half had the loose yokes.
Old Oct 20, 2008 | 10:13 PM
Did the loose yokes cause any kind of noise like a broke joint or knock?
WilliamBos
Sep 30, 2015 08:08 AM
blaze_master
May 26, 2015 11:18 AM
TEXASCAT
Feb 1, 2002 05:34 PM
CountryMiles
Oct 25, 2000 01:03 AM
