Honda Recon Oil Cooler
Old Oct 19, 2008 | 06:13 PM
xzachx2112's Avatar
Default Honda Recon Oil Cooler
I found one on eBay and read somewhere that the 2002 and newer recons come with them. What does the oil cooler do and would I be able to install it on my 2000 Recon??
Old Oct 19, 2008 | 06:45 PM
TLC's Avatar
TLC
A wast of time and money,the recon will never over heat and will run a million miles with or without one. Put the money in some tires or something that will make a worth while differance.
Old Oct 19, 2008 | 07:53 PM
xzachx2112's Avatar
I found a used one for like 5-10 bucks... what do they do?
Old Oct 19, 2008 | 08:02 PM
TLC's Avatar
TLC
They act as a car radiator but for the oil. Oil from the crank leaves the motor via oils lines and passes through the oil cooler and then returns to the motor at a more cooled off temperature. Most are even fan assisted for even more air flow through them even if the ATV is not in motion to create air flow..
Handy for the 350 Rancher,400/450 or 500 Foreman which has two of them by the way. But the 250s really do not stress out on heat like the bigger bores do.
Old Oct 19, 2008 | 09:08 PM
xzachx2112's Avatar
Thanks for the info! I just think it would be a cool thing to have. Now Ill have to see if it fits.
Old Oct 19, 2008 | 11:37 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
My Recon was a 99 or something like that, and I can't recall that it didn't have a cooler (????).
Anyway, you would need a new case so you could attach the fittings, and it just would never be worth the cost.
Old Oct 20, 2008 | 05:14 PM
xzachx2112's Avatar
if I have to get a whole new case, it is definately NOT worth it. I'd like to see how it looks like instaled though...
Old Oct 20, 2008 | 05:19 PM
TLC's Avatar
TLC
The are installed high and behind the protection of the front bumper. When installed right you should barley be able to see it.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Sep 8, 2015 10:51 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
