250 X Chain Adjustment
Old Oct 21, 2008 | 01:29 PM
ehawks's Avatar
Default 250 X Chain Adjustment
I just bought a 1987 250 x. Lots of slack in the chain and I can't find anywhere to adjust the chain? Sorry, this is my first quad. Been a two wheel rider all my life. Is there ajustments to take up chain slack on this model?
Old Oct 21, 2008 | 04:08 PM
budedm's Avatar
I have the same machine. Take a 6mm allen wrench and as you sit on the floor behind the ATV, loosten the two allen heads on the back of the axle. Then take the same wrench and fit it into one of the slots on the left side of the axle and rotate the axle ring by pushing or pulling on the wrench. You want more slop in the chain than you think. I believe it's 1 1/2". This is because the swing arm pivots in a different spot than the drive sprocket. So, if you were to bottom out the back shock, you wouldn't want the chain to be so tight at that point that it would break.
BTW, if you're interested in a racing cam for your 250, I have one and heavy valve springs that go with it.
Old Oct 22, 2008 | 09:18 AM
ehawks's Avatar
Thanks for the tips. Greatly appreciated. No use on he cam. I am very much a stock engine kind of person. Spend way too much time just keeping my cars on the road. When it is time to play I just want to ride, not race for 15 minutes till something breaks and wrench for three hours.
Old Oct 22, 2008 | 09:30 AM
budedm's Avatar
I know what you mean. In fact, I took the cam out of mine (previous owner put it in) and went back to stock.
Old Oct 24, 2008 | 02:02 PM
budedm's Avatar
Did you get your chain adjusted?
Old Oct 24, 2008 | 02:12 PM
ehawks's Avatar
Na, too much work, just gona sell it.
Actually it is up at our cottage. I already put stabilizer in the fuel so between that and the fact that I probablly won't get up there again till thanksfiving I'd say my four wheeling is over this year. Next time I go up I will be riding a snowmobile!
Old Oct 24, 2008 | 04:47 PM
budedm's Avatar
lol. I almost thought you were serious about selling it because it's too much trouble. If you do, I might buy it. I used to ride snow machines but then I moved to SC. Now it's just 4 wheelers. They handle almost the same as a snomobile and it's warmer.
Old Oct 25, 2008 | 01:11 PM
Y2daT's Avatar
ns Id love to have a fourth honda ........and on the chain adjustment dont forget to loosen or remove the bolt in the middle/bottom of the swing arm before turning it ,and you can get some on to jump on the back of the quad when your done while you inspect the chain tension or use a rachet strap to compress the rear shock (like budedem said to tight is not good) and if its clanking on the skid its too loose
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
