LOKKING FOR MORE TOP END
lol figured that would get a laugh. seriously though, you can check into a Hauck clutch kit. you can change the basket and springs and plates. that is a good place to start.
http://www.hauckpowersportsinc...46/Hauck_Products.aspx
clutch kit are only made to give it more pulling power to go up hill it will not give it top end
Clutch kit? meehhh.
Looking for top end with no worries of losing a little bottom end? Go with +1 in your front sprocket and get a smaller rear sprocket. Won't be as quick, but will have a higher top speed. Also, when your tires wear out, go with a little bigger tire size. Unless you have the standard big *** balloon tires that used to come on those....
<div class="FTQUOTE"><begin quote>Originally posted by: redmoon85
Clutch kit? meehhh.
Looking for top end with no worries of losing a little bottom end? Go with +1 in your front sprocket and get a smaller rear sprocket. Won't be as quick, but will have a higher top speed. Also, when your tires wear out, go with a little bigger tire size. Unless you have the standard big *** balloon tires that used to come on those....</end quote></div>
actually the wolverine is shaft drive...no chain and no sprockets.
Id trade it in for something not pink and with a bigger engine.IMHO
Clutch kit? meehhh.
