LOKKING FOR MORE TOP END
Old Oct 21, 2008 | 06:55 PM
kbennett6146's Avatar
Default LOKKING FOR MORE TOP END
I HAVE A 07 WOLVIE 450 ANY SUGGESTIONS FOR SOME MORE TOP END?
Old Oct 21, 2008 | 08:09 PM
cadillacdude1975's Avatar
ride downhill?
Old Oct 22, 2008 | 01:10 AM
LOL THANKS BUT THERES NOT ALOT OF HILLS IN NORTH CENTRAL FLA
Old Oct 22, 2008 | 01:36 AM
lol figured that would get a laugh. seriously though, you can check into a Hauck clutch kit. you can change the basket and springs and plates. that is a good place to start.
http://www.hauckpowersportsinc...46/Hauck_Products.aspx
Old Oct 22, 2008 | 02:58 AM
skj283's Avatar
ya do the sheave mod, it will buy ya about 4-5 mph, or at least it did me, and adds some pretty good stuff on the bottom too.
Old Oct 24, 2008 | 02:42 PM
josephh's Avatar
put you a rev box on it then put a power box on top of that
Old Oct 24, 2008 | 02:44 PM
josephh's Avatar
clutch kit are only made to give it more pulling power to go up hill it will not give it top end
Old Oct 24, 2008 | 02:50 PM
skj283's Avatar
a clutch kit may not give top end but getting the sheave machined does top and bottom.
Old Oct 24, 2008 | 03:47 PM
redmoon85's Avatar
Clutch kit? meehhh.
Looking for top end with no worries of losing a little bottom end? Go with +1 in your front sprocket and get a smaller rear sprocket. Won't be as quick, but will have a higher top speed. Also, when your tires wear out, go with a little bigger tire size. Unless you have the standard big *** balloon tires that used to come on those....
Old Oct 24, 2008 | 04:34 PM
mechanicock's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: redmoon85
Clutch kit? meehhh.
Looking for top end with no worries of losing a little bottom end? Go with +1 in your front sprocket and get a smaller rear sprocket. Won't be as quick, but will have a higher top speed. Also, when your tires wear out, go with a little bigger tire size. Unless you have the standard big *** balloon tires that used to come on those....</end quote></div>
actually the wolverine is shaft drive...no chain and no sprockets.
Id trade it in for something not pink and with a bigger engine.IMHO
