Stupic carb
Old Oct 22, 2008 | 02:33 PM
dude_25's Avatar
Default Stupic carb
I got a 95 warrior from my uncle. he left it parked for eight or nine years with gas in it. i cleaned everything out and rebuilt the carb. it started right up on the first try... lucky right. well it wont idle. It idles super high my pipe got cherry red, I just cant figure out how to get the idle down. i dont have a air filter in it right now but did not think that would cause the problem. I am stuck i tried for about four and a half hours yesterday to fix this problem. an suggestions would be great.
Old Oct 22, 2008 | 02:50 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default Stupic carb
welcome to forums dude_25. Check pilot screw. Screw it out a bit and see if that helps. Check for vacuum leaks also.
Old Oct 22, 2008 | 02:54 PM
DOCPHIL's Avatar
Default Stupic carb
AT THIS POINT I HOPE YOU TRIED TO LOWER THE IDLE WITH THE THUMB WHEEL SCREW IF IT IS NOT MAKING A DIFFERENCE REMOVE THE PLASTIC COVER AND LOOK TO SEE IF THE LINKAGE IS ALLOWING THE BARREL TO GO DOWN ALL THE WAY
Old Oct 22, 2008 | 03:33 PM
dude_25's Avatar
Default Stupic carb
i have tried the idle screw. no luck... the barrel moves just fine... i am telling you i am at a loss
dude_25's Avatar
Default Stupic carb
were would i be getting a vaccum leak from
Old Oct 22, 2008 | 03:49 PM
Koopa's Avatar
Default Stupic carb
<div class="FTQUOTE"><begin quote>Originally posted by: dude_25
were would i be getting a vaccum leak from</end quote></div>
Check the carb boots. grab a can of carb cleaner or ether and spray around in short bursts. If you notice a change in idle you'll find where it's sucking.
You said you rebuilt the carb. Did you change the idle jet?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
