Rear wheels have lots of SLOP
Old Oct 23, 2008 | 10:31 AM
Resident Dawg's Avatar
Default Rear wheels have lots of SLOP
Rear tires have alot of play/slop in them.
Is it the hubs, Axel or both that need to be replaced?
Thanks for you help.
Old Oct 23, 2008 | 10:57 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
What's the ride?
Old Oct 23, 2008 | 11:00 AM
warrior 350 mid 90's
Old Oct 23, 2008 | 11:38 AM
Endo's Avatar
Pull the cotter pin and take off the axle nut. Slide the spindle off and make sure splines are still in good shape. Axle and spindle. Could also be as simple as the castle nut needing tightened. Also check carrier bearings while you have it off of the ground.
Old Oct 23, 2008 | 11:48 AM
Sounds easy enough. I hope it is just tightening the castel nut, that would make life REAL easy. LOL
Old Oct 24, 2008 | 02:00 PM
Rear AXLE is FOOKED!! the threads are wore out...u can pull the nut off with out unscrewing it.
Any ideas for an inexpensive replacement axle?????
Old Oct 24, 2008 | 02:40 PM
Endo's Avatar
Not sure what a good cheap one would be. I run a durablue eliminator and have had very good luck. I do know that that there is a g-force or something like that, that is suppose to be reasonable.
Old Oct 24, 2008 | 02:50 PM
I have been looking on e-bay, found a stock replacement AXEL the guy wants $70.00 shipped. does not look pretty at all( rust, dirt, .ect)....but all the splines are good and it is stright.
Old Oct 24, 2008 | 05:57 PM
mechanicock's Avatar
get it and sand blast it my 88 warrior had a stock axle on it and it was bulletproof
Old Oct 24, 2008 | 07:33 PM
Jeepsterbrad's Avatar
I got an OEM replacement axle on ebay for 115, you might be better off just trying to find a brand new one for a little more and not have to screw with anything used
Sandman2.0
Jul 21, 2015 09:03 AM
WilliamBos
Jul 13, 2015 02:11 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
