99 kodiak....please help
Old Oct 23, 2008 | 11:57 PM
XessReality's Avatar
Default 99 kodiak....please help
so i was winching a log out of the way when the quad starded to slip. as it was in reverse already i gave her a little gas to hold my ground. all of the sudden i'm sitting on a stalled quad that wont start.
many hrs of recovery later, its quite obvious that i burnt up the coil ground wire pretty good. checked other wires...all good. replaces burnt wire....no spark. so i pull the coil, seems to test ok... working on pulling the stator, but i could really use some help wrapping my head around what happened in the first place and why i still have no spark.
best i can figure, when i gassed the quad while winching i must have somehow spiked the charging/ignition system and it overloaded and burnt up.
as best as i can tell the winch was installed properly(just bought the quad a week ago), and though ive never put it under such stress before, it has been used here and there to self recover...
i ran some prelim tests on the stator wires, but without a referance as to what good values are i can only use logic.... i am pretty mechanically inclined and am starting to feel like i'm missing the bigger picture here.......any ideas???
PLEASE HELP!!!
Old Oct 24, 2008 | 02:26 AM
Traildad's Avatar
Is it possible that the wire was already damaged and it just went dead at that moment?
Old Oct 24, 2008 | 02:11 PM
...well i guess its possible, but shouldnt the charging system regulate itself so as to prevent such an overload? (assuming it wasnt damaged already) and furthermore, why am i still getting no spark?
i pulled the stator cover and inspected/tested to the best of my ability and it seems to all be within reasonable limits, but as stated previously, i am going off of general #s for resistance as i am having a hard time finding exact specs for a 99 kodiak.
i just bought this quad (my first) a week ago..... please, any help getting her back on the trail would be awsome...thanks in advance!!!
Old Oct 24, 2008 | 02:18 PM
josephh's Avatar
this happend the same way on my yamaha big bear check the main fuse it is blowed the main fuse cost about 50 cents to 1 dollar
Old Oct 24, 2008 | 04:25 PM
the 30 amp....? its fine. btw ...even though no spark everthing else seems to work just fine...including the winch/lights ect.... any more ideas....PLEASE!!!
Old Oct 24, 2008 | 07:38 PM
josephh's Avatar
have you tried a new spark plug if the plug is bad or it might be the plug wire but i have winched out a lot of stuff i have rode my hard i have hot rod it and that is the only thing i would know hope you get it fixed
Old Oct 24, 2008 | 07:39 PM
cadillacdude1975's Avatar
if the stator is bad, you wont get a spark.
Old Oct 24, 2008 | 07:47 PM
josephh's Avatar
have you checked the ingition fuse if it is bad it wont start
Old Oct 24, 2008 | 08:35 PM
all fuses checked and tested...... new plug.... all ignition parts within spec as far as i can tell...anyone have specks for a 99 kodiak 400 ignition/charging/cdi/reg/rect system????
Old Oct 25, 2008 | 12:15 AM
HeftyLefty's Avatar
Download a manual here for $6.95.
www.powersportresource.com
