mew to site...question
Old Oct 24, 2008 | 06:55 AM
crahinit_2008's Avatar
Default mew to site...question
Hello All
Seems to be a great site. Can anyone give me instructions on how to change the belt on a 04 kodiak 450. Will i need to get a clutch puller tool. If so any ideas where??
Thanks In advance
Old Oct 24, 2008 | 07:40 AM
TLC's Avatar
TLC
How to change a belt
I never seen a belt that you need a tool if you need to change it.
There designed that they can be changed on the trail.
Old Oct 24, 2008 | 02:43 PM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
There designed that they can be changed on the trail.</end quote></div>
First off welcome to the Site!
That video is good, it is however for a Polaris - I know the Yamaha isn't much different... One thing I recommend is to put Antisieze compound on all the bolts that hold the belt cover onto the engine.. those are steel bolts going into aluminum cut threads... I also recommend going with an OEM Belt..
Right from the Yamaha Manual:
Note: Once your D/L the manual it is on Page 3-34(101 of 397)
Replacing steps:
STEP 1: Install the bolts (M6x1.0x45mm) into the secondary fixed sheave hold.
STEP 2: Tightening the bolts will push the secondary sliding sheave away, causing the gap between the secondary fixed and sliding sheaves to widen.
STEP: 3: Remove the V-belt from the primary sheave and secondary sheave.
Install the V-belt.
STEP 1: Install the V-belt so that its arrow faces the direction shown in the illustration.
STEP 2: Remove the bolts.
Here is the link to the Yamaha manual for the 03-06 Kodiak 450's. Changing the
Manual
http://www.savefile.com/files/74511
The link for the manual works but sometimes you just need to work it a bit...
1. Click the link in the Message
2. Scroll down to the Section in the BLUE Box that says "05-06 Kodiak 450" and Click "DOWNLOAD FILE"
3. Your download SHOULD start...
IF NOT
4. Scroll down to the Bottom.... where you will see
" Your download should begin shortly.
If it does not, try <u>Download file now</u>
That should do the trick [img]i/expressions/beer.gif[/img] [img]i/expressions/beer.gif[/img] [img]i/expressions/beer.gif[/img]
Old Oct 24, 2008 | 04:26 PM
thanks for the replys guys.
Are the bolts to widen the sheaves a special bolt, or will a hardware store caryy them?
Thank you again
great site!!!
Old Oct 24, 2008 | 04:42 PM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: crahinit_2008
Thank you again
great site!!!</end quote></div>
Yea.. a Hardware store should carry them as long as they have metric hardware.. you want an M6x1.0 pitch ( threads per mm) x 45 mm long. In fact.. now that I know those bolts will help.. I am going to pick up a 1/2 dozen.. though I know I only need 2
Ski-doo snowmobiles come with a threaded tool to install into the Secondary which help make changing the sled belts easier...
