New piston and rings
Old Oct 25, 2008 | 02:30 PM
bweymouth's Avatar
Default New piston and rings
I bought a 2001 Polaris Sportsman 90 for my son and it's not running right. I checked the compression and it's around 60psi....time for a new piston and rings. Can I just put in the standard bore piston and rings, or should I bore it out?
Old Oct 25, 2008 | 03:31 PM
eggenz7's Avatar
try putting about a 1/8 cup of oil into the spark plug hole then check compression. if it gets up to around 120 or so i would say i just needs new piston and rings. if it doesnt reach that mark then you need to bore it out.
Old Oct 25, 2008 | 04:52 PM
bweymouth's Avatar
Thanks! I'll give it a try.
Old Oct 25, 2008 | 05:27 PM
ftwflh's Avatar
You can get a topend ki with new cylinder,piston,gasketst from a guy on ebay for less than you can buy a piston and bore it.
And yes you WILL need to bore it.
Old Oct 25, 2008 | 05:42 PM
bweymouth's Avatar
Do you have any information about this guy? Does he have a ebay store?
Old Oct 25, 2008 | 09:05 PM
ftwflh's Avatar
Do a search for Eton 90 pistons check box for titles and description
Old Oct 26, 2008 | 10:49 AM
bweymouth's Avatar
I found the Eton top end kit. Will this bolt up exactly as regular Polaris parts? Will it perform as well as genuine parts?
Thanks!
Old Oct 26, 2008 | 11:50 AM
ftwflh's Avatar
Eton makes the Polaris 90s.Yes it will fit
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
