fixed belt lite butt....
Old Oct 27, 2008 | 01:40 PM
repairman140's Avatar
Default fixed belt lite butt....
03 prairie 4x4 will not go fast after belt lite reset. will go in 4x4 but lite does not come on, 4x4 works. i power washed and cleaned atv to sell all of a sudden its sputtering and backfiring. need help
i took the cover off the belt should the switch be in the on or off position ?
Old Oct 27, 2008 | 11:37 PM
Rattlebars's Avatar
What size Prairie? Did you do all this stuff?
http://www.rattlebars.com/prairie/belt.html
Switch goes to the ON position for running.
Old Oct 28, 2008 | 10:51 AM
I did. it is running fine now. i set the idle up on the carb, let it run for 10 min on 1/2 choke, took choke off lowered idle slightly and took off like its supposed to. one small backfire when i slowed down. im gonna drain gas and put new gas in.
can i put an additive in for the carb like in a vehicle ? thanx for the response.
mike
Old Oct 28, 2008 | 04:08 PM
Rattlebars's Avatar
Yup, use Sea Foam. Works great.
Old Oct 30, 2008 | 11:42 PM
Mudatv's Avatar
I will give Sea Foam a second vote. It is a great product and does everything that it claims to. I used it in one of my bikes that was so gummed up that the only way it would run was with full choke. After about 1 gallon of gas with Sea Foam, it ran well enough to go on a ride. I now use it with every tankful.
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Steeldon
Sep 9, 2015 09:38 AM
