1987 warrior xt
Old Oct 27, 2008 | 03:38 PM
oldschooldog's Avatar
Default 1987 warrior xt
hi newbie here just looking for some help i've got a 87 warrior not firing (new coil new stator ) hoping not the cdi box can anyone tell me somethings to try or something else to check need help bad guys Text
Old Oct 28, 2008 | 01:45 AM
beefy46172's Avatar
Loves To Ride!
Check the orange wire at the coil for a pulsing current when turning it over. If nothing there check it at the CDI. Nothing there, check the wires coming from the stator and if they have a pulse check them also at the CDI plug. If the stator is pulsing to the CDI but the CDI isn't relaying it to the Coil then it is fried. I just went through this problem. Also make sure you're ground on the coil is good as well.
Old Oct 28, 2008 | 12:44 PM
thanks i'll try it let you know what i come up with
Old Oct 28, 2008 | 09:03 PM
XessReality's Avatar
hey....i have a 99 Kodiak 400 but same no spark issue... can you elaborate a bit on the pulse thing... i have tested all ignition components with a meter and they seem ok, but still no spark. i have 12+ volts at the orange wire with ignition on and when it cranks my meter goes crazy....still no spark
Old Oct 30, 2008 | 01:51 PM
beefy46172's Avatar
Loves To Ride!
If your ground is good as well on the coil then you either have a bad coil, plug, or plug wire. Obviously try a new plug first, as they do develop shorts from time to time.
Old Oct 30, 2008 | 07:47 PM
new coil and plug...will let ya know
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Steeldon
Sep 8, 2015 10:51 AM
