Weird 400ex Problem
Old Oct 27, 2008 | 07:04 PM
2003 400ex rider 911911's Avatar
Default Weird 400ex Problem
Ok, here goes. cant seem to figure it out: If my quad is sitting there, I turn the key but the light doesn't come on. I know the first thing that comes to mind is a battery or alternator problem, but my electric start is working perfectly, I recently replaced the battery. Also if the quad is in neutral, and the key is on, the electric start won't work, but if I pull in the clutch it starts right up. Also I know the first thing that comes to mind with that one is that it's in gear, but when I let the clutch out it continues to idle, showing me that it is in fact in neutral. Any help will be greatly appreciated. thanks.
Old Oct 28, 2008 | 02:02 AM
yzballa08's Avatar
Check your neutral ground under ur shifter for a bad connection,do u have a aftermarket clutch?.....also might be your clutch switch on ur clutch perch
Old Oct 28, 2008 | 09:46 AM
ok ill try that thanks
Old Nov 3, 2008 | 09:20 PM
do you have, or know where I can get a diagram of this, or could you simply explain it to me, because I dont understand "under the shifter" or "the switch on the clutch perch". what do these two look like? thanks, burke
Old Nov 4, 2008 | 05:47 PM
strkmad's Avatar
Mine does the same thing off and on. There is a neutral switch to the left of the shifter mount below the gear (according to the book), chances are it's bad. I just pull the clutch in to start if the switch doesn't work. But if you really want I can send you the page that explains how to test/change it and shows a pic.
Old Nov 4, 2008 | 06:45 PM
could you send me an image of that please?
Reactant
Mar 30, 2022 02:08 AM
hondarider1234
Jul 21, 2015 11:53 PM
95wolv
Jul 21, 2015 12:25 PM
chammerbeck
Jul 17, 2015 08:06 AM
cSchwartz
Jul 12, 2015 07:42 PM
