honda 110 huge oil leak( need help)
Old Oct 28, 2008 | 01:58 PM
kearnsdv's Avatar
Default honda 110 huge oil leak( need help)
hey i had a post on here before about my honda 110 atc. i got a new head and put it on. i bought a manaual on ebay. i set the timing right. so i put it all back together and i pulled it and it started right up. but i looked down and i saw that it was pooring out oil. what do you thing it could be? i got new gasket so i think it i could of messed up the gasket where the timing chain is because so much oil came out. what do you think?
Old Oct 29, 2008 | 01:00 AM
SMFREY's Avatar
I think you do not have assembled correct
There are seals that go in there other than the head gasket
This is to oil the Cam and timing chain
My bet they are not in anymore
I would not run to long
As engine only holds 3/4 qt oil but then it will stop leaking
Ray
Old Oct 29, 2008 | 12:49 PM
kearnsdv's Avatar
ok so i took it apart 3 times now and did everything by the atc 110 book and it still poors out oil. i checked the rubber gasket where the timing chain is and it looks good. so how many gaskets are there where you connect the cylinder head to the cylinder. there is the copper head gasket, the rubber one for the timing chain, is that it? am i missing one? please leave feedback. i dont know what else to do.
Old Oct 29, 2008 | 01:05 PM
SMFREY's Avatar
What about the supply through the stud assembly whrer there is a sleve and O-Ring
Ray
Old Oct 29, 2008 | 02:28 PM
kearnsdv's Avatar
i dont know but i made a little video so you can see what gaskets i have and to show you where its leaking. heres the link http://www.youtube.com/watch?v=3tYEOUoAtgk . i could make one of when its leaking if you wanna see?
Old Oct 29, 2008 | 02:54 PM
SMFREY's Avatar
The gasket you show is in the Cam chain area
The oil to supply the cam and chain is pushed up one of the studs that hold the cyl head on
also this origionaly had a Cap nut on so not to allow oil to leak past threads
My bet is that is where oil is leaking
There is what looks like an alignment sleve but there should be an O-Ring on outside
Thanks
Ray
Old Oct 29, 2008 | 03:16 PM
kearnsdv's Avatar
that sounds like thats it. look in the picture i dont have those so it has to be that right?
<a href="http://s490.photobucket.com/al...=view&current=110.jpg" target="_blank"><img src="http://i490.photobucket.com/al...r266/kearnsdv/110.jpg" border="0" alt="Photobucket"></a>
Old Oct 29, 2008 | 04:34 PM
kearnsdv's Avatar
that was it. i got it off my old cylinder head. it doesnt leak anymore. thank you for all your help.
Old Oct 31, 2008 | 11:10 PM
SMFREY's Avatar
Those also keep head from moving around and causing other issues
Like blowing out head gasket
Glad that was a simple fix
Ray
Nondem
Feb 22, 2020 12:20 PM
nachop
Feb 14, 2018 06:57 PM
toonces
Aug 13, 2015 01:48 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
