why does my banshee run bad?
would the pick up coils make it run bad? the right side runs perfect and the left side will run thenit will miss and it boggs really bad when you start out and floor it.
and when you are in foruth or fifth gear,when you shift it studderes and then it kick back up in to the rpm. it runs fine at high rpms,but at low rpms it runs like shiot!!!!
it is not the carb!!! i have a lectron single carb and there are no jets!!! i just put new plugs on it. i bought another coil and itran the same so i think it might be the pick up.
could one side of the stator go bad? i got it up to 75 mph and with the mods i have people said it should go faster
stage IV head with 20 cc domes
fmf fatty pipes and power core 2 silencers
bored . 50 over
new coil
new reeds
new air cleaner
stock sprokets
bored . 50 over
new coil
new reeds
new air cleaner
stock sprokets
yea it is, ive heard of other people having those problems, its not the ignition coil i would think, its the stator like you said i would think, take and switch the sparkplug boots and then see if its still running bad on that one side. my bet is either theres a bad crank seal, or your stator is done, check out the wires and if there frayed or the insulation is gone then it will be most likely the prob. if it is then id def get a new stator from Rickys.
i tested the coil and it has no resitance at all. i took the flywheel off and it looks like someone dipped it in white paint. white paint was covering the stator coils ,but i cleaned it off and it still didnt work. the stator tested fine so it isnt that even though it is the most logical answer. i bought another coil on ebay and it still didnt work but that was before. it also had a brand new ricky stator coil and that has no resitance too. so i am going to order a new coil.
could it be the cdi box? but if it was wouldnt it stop working on the one side altoghether?
i got over my fear and switched the boots. it ran exactly the same on the same cylinders!!! so what now? im going to buy a new coil but i might get a cdi just for the heck of it.
