why does my banshee run bad?
Old Nov 4, 2008 | 12:07 PM
91Warrior357's Avatar
Default why does my banshee run bad?
wow, hmm hopefully a crank seal isnt bad, maybe you need to go to www.bansheehq.com , when you do a spark test is there even spark on both sides? does one pipe get hotter then the other? theres not much more i know about on shee's but some1 on the banshee site should be able to help
Old Nov 4, 2008 | 04:44 PM
stageIVbanshee's Avatar
yeah the one side never gets hot.i will go to bansheehq and see waht they say
Old Nov 4, 2008 | 08:42 PM
beefy46172's Avatar
Loves To Ride!
If switching the boots didn't make the opposite cylinder fire wrong don't waste your money on a coil--it won't fix it. Something is wrong with that side of the engine.
Old Nov 5, 2008 | 07:19 PM
what could it be then? i am going to take the head off to look at the pistons to see whats up anyway
Old Nov 19, 2008 | 10:09 PM
  #15
scrambler400enoge's Avatar
Shapeshifter Rider
no this might be a carb sync I heard someone say that if the carbs aren't synced right the engine can run on A cylinder.
Old Nov 20, 2008 | 02:34 PM
  #16
Endo's Avatar
Check compression!
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
