Foreman Rubicon 500 oil pump chain slack
Yes, I have seen them crazy loose, even the new chains when installed. I have also seen the oil pump chain drive chain gear oval out the notch that slips over the flat on the pump shaft.
----- Gimpster -----
i noted that mine was slack as crap when i pulled the front cover. if you look at the picture in the FSM it even looks slack there.. idk. every thing runs good so I guess its ok.
