Foreman Rubicon 500 oil pump chain slack
Old Oct 28, 2008 | 11:36 PM
rruser's Avatar
Default Foreman Rubicon 500 oil pump chain slack
How much slack should there be on the Rubicon's oil pump chain? Also, should the sprocket on the end of the oil pump move around a bit?
Thanks.
Old Oct 30, 2008 | 01:31 PM
rruser's Avatar
Anyone?
Old Oct 30, 2008 | 06:42 PM
Gimpster's Avatar
Yes, I have seen them crazy loose, even the new chains when installed. I have also seen the oil pump chain drive chain gear oval out the notch that slips over the flat on the pump shaft.
----- Gimpster -----
Old Dec 29, 2008 | 08:05 PM
Only1Stegall's Avatar
i noted that mine was slack as crap when i pulled the front cover. if you look at the picture in the FSM it even looks slack there.. idk. every thing runs good so I guess its ok.
ltrmc02
Aug 22, 2021 02:34 PM
mark23
Oct 1, 2015 09:57 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
