blaster problem
Old Nov 1, 2008 | 08:23 PM
stageIVbanshee's Avatar
Default blaster problem
it has a new stator, flywheel, cdi unit, TORS brain and still no spark. what could be wrong? if i were to disable the TORS how would i do it?
would a bad kill switch make it not work? what else is wrong?????
plz help!!
Old Nov 2, 2008 | 03:22 PM
WLD_OTZ's Avatar
Not a yami guy, but the kill switch has buggered me on a couple of occasions, an it is easy to check out.
Old Nov 2, 2008 | 06:38 PM
how do you check it. it was a thought on my mind but didnt know how to check
Old Nov 3, 2008 | 11:11 AM
WLD_OTZ's Avatar
There are two types of switches, normally open and normally closed. you must first determine that the switch is in the RUN position(I aint bein a smartass, I have had the switch in the OFF mode before and troubleshot the heck out of my bike before I noticed it!). Using a normal mutli-meter, in the continuity mode, check the two wires with the switch in run and then in off, and make sure one is open and one is closed. Your multi-meter will make a tone when you have continuity.
If you get a tone in one position and not the other, 90% says that your switch is good.
If that fails, get yourself a shop service manual, I am sure you can download somewhere online, and trouble shoot it using the book.
Sorry, that is about the only advice I can give you on that one.
Good Luck!
John
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
