fuel system problems 300ex
Old Nov 1, 2008 | 09:08 PM
juttin_15's Avatar
Default fuel system problems 300ex
my 300ex keeps pooring fuel into the air box, has no power on the lower end, and is nearly impossible to crank
Old Nov 1, 2008 | 09:12 PM
wanfernandez's Avatar
sounds like a carb problem take it off and clean it good put it back together and try it then.
Old Nov 3, 2008 | 05:03 PM
ikeyrider's Avatar
Hmm so is the fuel traveling back the air intake into the filter? That sounds suspicious because there should be suction from the engine so fuel cannot go backwards, i would also advice taking off the carb and check the slides and gates, i suppose if one was stuck shut fuel may be able to dribble backwards into the airbox.
Old Nov 3, 2008 | 09:08 PM
juttin_15's Avatar
the float was stuck
juttin_15's Avatar
the float was stuck
Old Nov 4, 2008 | 10:10 AM
ikeyrider's Avatar
that has happened to mine be4, i had to open up the carb and mess w/ the floats/shutoff needle, if the carb runs dry it might do it again.
Old Feb 13, 2009 | 03:01 PM
Rousey's Avatar
Wrong section.
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 10, 2015 04:54 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
