new to me: 88 fourtrax 300
Old Nov 2, 2008 | 10:05 PM
BlackCloud556's Avatar
Default new to me: 88 fourtrax 300
Tonight i picked up a wheeler from my wifes family farm. the thing has been sitting for at least 4+ years with out moving. Both rear tires are flat and dry rotted, seat is trashed, gas tank is a little bit rusty. They also told me that it sometimes has an electrical gremlin that causes it to quit running.
I did put some fresh fuel in it, and got it to run for about 30 seconds before it popped, and sputtered out. and my battery died.
so here it is, such that it is..
this is my first atv, so any advice would be appreciated.
also does anybody know where i can find any manual at?
Old Nov 2, 2008 | 11:16 PM
cherokee99's Avatar
congrads, it will be an awsome mechine when you get it running. clymer manual would be good. try on dennis kirk.com
Old Nov 2, 2008 | 11:32 PM
scrambler400enoge's Avatar
Shapeshifter Rider
That is the first utility I have seen with kick start good luck!
Old Nov 2, 2008 | 11:38 PM
well it also has an electric start thank god
Old Nov 2, 2008 | 11:46 PM
cherokee99's Avatar
kick start is fun ,sometimes. i found out it hurts your foot like hell after the first 10 or so kicks. id get that electric start workn soon
Shapeshifter Rider
No I meant good luck geting it back to its old glory that is one of the best utilities ever made.
Old Nov 2, 2008 | 11:58 PM
thanks for the replies guys.
well to me it looks like my biggest problem right now is getting the dry rotted tires fixed. then getting the carb cleaned out, and ive found the left brake lever is all jammed up. gonna have to figure out how to either unstick it, or just buy a new cable
Old Nov 3, 2008 | 07:50 AM
durabostbay's Avatar
Left lever is for the rear brakes. The arm coming out of the rear brake drum is probably seized up. See if you can move the arm with your hand, you might have to undo the cables to get a more accurate feel.
Old Nov 3, 2008 | 06:53 PM
ill try that. thanks
Old Nov 4, 2008 | 12:46 AM
well i got alot of the thing tore down tonight
and i got the carb taken off. I have two questions about it. first, what is the little thing i have circled in red? it almost looks like a hookup for a breather tube. and second. what is the black **** for? is it just a primer?
