1984 trx 200sx
Old Nov 4, 2008 | 06:07 PM
hopy-dah's Avatar
Default 1984 trx 200sx
I have a 1984 trx200sx that when I use the pull start rope it turns the starter also which makes it very hard to start. I have had the gears out and can not see any reason why this is happening. Does anyone have any information as to why this is hapening? I am concerned that if I use the electric starter that it will do some damage In this condition. I have removed the starter gear so I can use the atv.
Thank You for your help.
Old Nov 4, 2008 | 07:11 PM
HondaMechanic's Avatar
Are you sure of the year and model ..
On a 1984 TRX200 there is a oneway clutch on the flywheel for the electric starter that uses 3 rollers , I would guess 1 or more are stuck or jammed ..
Honda didn't make the TRX200SX until 1986 and they used a sprag clutch (oneway clutch) for the electric starter ...
Old Nov 5, 2008 | 11:48 AM
hopy-dah's Avatar
Your absolutely right! It is a 1986. I miss read the tag. I will have to pull the flywheel and check out the one way clutch. Thank You again for your help.
timster911
Jul 13, 2015 01:57 PM
ATV_MAN
Oct 19, 2004 09:56 PM
RobertJ
Jun 23, 2001 12:48 PM
JRM
Sep 19, 2000 07:38 AM
mudslinger85
Aug 10, 2000 10:58 PM
