ds650 faster
Old Nov 5, 2008 | 10:20 PM
everlast1's Avatar
Default ds650 faster
trying to make my ds650 faster got the big gun rev box, slip on pipe dont know how to jet it put a 185 jet in it from dyno jet kit, what is the best way to jet it? needel position? Got beat by a raptor 660 pissed me off! Does a rectifier make it Quicker. srocket change? Can any body help? Dont need top end speed just faster.
Old Nov 6, 2008 | 02:21 AM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Go to a 15 or 14 tooth front sprocket, and get an aftermarket carb like a TM45 or Mr. Horsepower Lectron 46hv. You will more than likely be faster than the 660. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 8, 2008 | 01:39 AM
cynick's Avatar
What year is the DS? A few minor things can liven these beasts up.
Old Nov 12, 2008 | 05:16 PM
Bomb-s-quad's Avatar
i think stock this must beat the 660 raptor...i have 05 DS 650 x when my quad is all stock no exhaust no jets and my friend 660 raptor got full gytr system i beat him eaisly..
Old Nov 13, 2008 | 01:21 AM
NickDS650's Avatar
Yea i have both the DS and Raptor, DS is faster, but the Rappy is snappy and will give a challange, sounds like your not jetted right which will kill ur performance, even off by the slightest bit makes a huge diff, a rev box and pipe like u have will satisfy you, for a while lol, then u might catch that "must go faster" bug and u can hit up the carb, intake, etc. a 185 is a big jet for a slip on id say, read your spark plug, if its black your to rich, if its white your to lean, try a 175 and take your air box lid off, your engine will tell you exactly what you need, even if u go slow down a short stretch at a steady throttle, if it bogs down some than its getting to much gas so ur jet is to big, if it sputters and hesitates than its starving for more gas so your jet is to small
Old Nov 18, 2008 | 08:30 PM
everlast's Avatar
Its a 2000, pro circuit t4 pipe
Old Nov 18, 2008 | 08:34 PM
everlast's Avatar
its a 2000 with a pro circuit t4 slip on big gun rev box and it seems to be jetted right, the spark plugs are brown.
Old Nov 18, 2008 | 08:36 PM
SilverBomb's Avatar
Yep, sounds like it's time for you to go with a new aftermarket carb and front sprocket. You will be pleased to say the least! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 18, 2008 | 09:59 PM
cynick's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: SilverBomb
Yep, sounds like it's time for you to go with a new aftermarket carb and front sprocket. You will be pleased to say the least! [img][/img]</end quote></div>
Yep, time for carb and new intake box, or the lack of. Just by putting on a tm 45 or a lectron46 will be night and day different.
Old Nov 20, 2008 | 07:54 PM
everlast's Avatar
I cut the lid off the air box, bought some Holeshot 6 ply tires for better traction. Can I get away with buying just the front sprocket instead of the kit with the rear and chain. How many teeth should I go down?
