Raptor: Best clutch lever and brake block off?
Old Feb 2, 2001 | 03:33 PM
swytak's Avatar
I'm ready to change this junk parking brake, it doesn't work half the time anyway. Unless I adjust it every single time I ride. So, i'm wondering what others are using. I'm considering PEP easy clutch lever and perch. What about brake block offs? Does any brand make that much difference? As long as it fits, how much difference can there be? How about NAC's anodized for $12.00. So what do you guys use? Thanks!
Old Feb 2, 2001 | 03:38 PM
xtreme165's Avatar
I put a cr honda perch and lever on mine and a Nacs brake block off. The block off doesnt matter and the cr perch/lever gives you even an easiear clutck pull.
Old Feb 4, 2001 | 02:22 AM
mascann's Avatar
yeah i like the CR style pearch also. but how do you make it run after with the 2 extra wires. i haven't put mine on yet cause i wasn't sure how to fix the wires.
Mike
Old Feb 4, 2001 | 03:42 AM
Mudrat454's Avatar
I just put my perch and block off on. I used a Pep ez-pull which is a cr style lever and Nac's block off plate. There are four wires to deal with. I unplugged the white connector(this is two of the wires)( it needs to be an open connection to work) I would seal it with something so it will be protected from the elements. The other two are sort of green quick disconnects and I unplugged them and plugged the two from the machine back together. It seems to work fine.
Old Feb 4, 2001 | 04:08 AM
mascann's Avatar
thanks i will try in the am where is polo?
Old Feb 4, 2001 | 04:29 AM
Mudrat454's Avatar
Polo is about 50 miles Northeast of KC just east of I-35. Where are you located at?
Old Feb 4, 2001 | 05:22 AM
mascann's Avatar
3 hours south of KC - near Branson
STLyamwar
Jul 25, 2020 04:44 AM
Stirling
Aug 9, 2015 01:49 PM
WilliamBos
Aug 8, 2015 07:26 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
