black nasty spark plug?????????????
Old Nov 5, 2008 | 10:33 PM
wanfernandez's Avatar
Default black nasty spark plug?????????????
So I pulled out my plug and adjusted my valves today and my plug is nasty and black so of corse I replaced it. What causes a black plug my $00 burns a little oil would that be the cause? Also does any one know if you can replace the balljoints on a 400EX??
Old Nov 6, 2008 | 09:34 AM
Y2daT's Avatar
my oil burners make the plugs black..lol
the ball joint appears to be pressed in to me,but on oem parts look up it only sold attached to the a arm..however I have some 250x arms that the lower ball joints appear to have been cut off and replaced with L shaped ball joints that bolt through the tube after the originals were cut i can email pics if u like
Old Nov 6, 2008 | 11:04 AM
snorulz's Avatar
it could also be running rich
Old Nov 8, 2008 | 10:52 AM
jfwyatt's Avatar
valve seals are bad to leak after a few years does it smoke at startup? ball joints are non replacable on stock arms. you can get a whole set used on ebay for under $100 or so.
Old Nov 8, 2008 | 01:37 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Valve seals / guides will leak on startup and compression deceleration causing smoke.
Old Nov 10, 2008 | 11:02 PM
From what you are saying it might be the valve seals but it smokes when youu reve it up not when you let off . Thanks for the info i have made a bid on the A-arm that I need.
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
