Battery
Old Feb 2, 2001 | 05:45 PM
nauvooguy's Avatar
How long should one charge the battery of a 99 tblazer?
Old Feb 2, 2001 | 07:12 PM
motorman's Avatar
i charge mine at 2 amps for 1 hour every month when the quad is stored for the winter.
Old Feb 2, 2001 | 11:18 PM
nauvooguy's Avatar
Well what if the battery isnt at 2 amps, and is charging at 0?
Time for a new battery,right?
Old Feb 3, 2001 | 09:24 AM
motorman's Avatar
sounds like new battery time to me. these small batterys seem to open up inside and lose contact. since i do not use my quads in the winter i remove the batteries and once a month i charge them at 2 amps for about an hour. i found that if you let them go dead and leave them set,in the spring they will no longer take a charge. my wifes trailblazer is a 97 and still has the orignal battery and i just replaced the battery in my 96 xplorer last spring. today is charge day as i am leaving for FLA. for a month to go to the NASCAR races and i hope this winter weather is over when i get back.
Old Feb 3, 2001 | 01:31 PM
CaptNemo's Avatar
Will the battery run the lights, or start the engine when disconnected from the charger?
If the battery is fully charged, the meter on the charger will read 0 Amps.
Is the battery holding voltage? About 12-13 volts is good.
Have you checked the electrolyte? Have you used a battery hydrometer?
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
