Big Red Head
Old Nov 7, 2008 | 02:26 AM
xrtfan's Avatar
Default Big Red Head
I'm looking to replace the top end of my 1985 250es big red. because its smoking blue smoke.Someone mention that i might replace the cam chain,its not not or making noise.My service manual doesnt show how to replace the chain but the guides,Any help?
Old Nov 8, 2008 | 09:26 AM
pcollins's Avatar
the blue smoke has nothing to do with the cam chain. its the valve guides. get a good manual or work book for you ATC and it will most likely explain how to do the valve guides.
Old Nov 9, 2008 | 12:29 AM
xrtfan's Avatar
Hey,thanks
Old Nov 9, 2008 | 12:34 AM
pcollins's Avatar
no problem. my ATC needs valve guides as well. just BE CAREFUL with the timing. while the engine is apart do not turn it and don't let anyone else turn it. i had that happen and i had to take the head off and rotate it 3 times to get the timing spot on. it does run now though. thank god.
Old Nov 9, 2008 | 09:14 PM
xrtfan's Avatar
well that sucks ,my manual told me to turn it over to get the cam chain gear bolts off.
Old Nov 9, 2008 | 09:49 PM
HANDM's Avatar
When I did the rings on my 200x I just used a piece of wire to hold the cam sprocket onto the chain. Then tied it up to keep tension on it and had no trouble
Old Nov 9, 2008 | 10:12 PM
pcollins's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: xrtfan
well that sucks ,my manual told me to turn it over to get the cam chain gear bolts off.</end quote></div>
just don't turn it over while the head and flywheel arent connected. if you turn one, turn the other so they stay in sync.
Old Nov 9, 2008 | 10:27 PM
xrtfan's Avatar
Gotcha ,hey is it ok that i took the cam chain sprocket off and using a wire to hold the chain.so when i get a new cam what do i do to get everything synced? or tdc?
Old Nov 10, 2008 | 07:04 AM
HondaMechanic's Avatar
Old Nov 10, 2008 | 09:59 PM
xrtfan's Avatar
Thank you very much.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
