750 brute 2wd/4wd dash lite flashing
a friend of mine has a 750 brute like mine ever since he changed the battery his 2wd/ 4wd dash lite flashes back and forth between the 2 of them both 2 and 4wd functions work properly just the lite flashes back and forth
i'm having the same problem. i believe its something with the actuator brake controller which is next to the engine. because my friends 750 actuator works fine and his dash doesnt flash but when i install my brake actuator his dash starts to flash. I'm not sure if its some sort of warning that the actuator is going to go bad.
<div class="FTQUOTE"><begin quote>Originally posted by: hondarider94
should of bought a HONDA</end quote></div>
I've noticed your helpful comments over and over.
Now you've been reported.
Great insight and very creative.
Try to be a little more helpful next time.
