gear box
Old Nov 9, 2008 | 08:39 AM
ct66's Avatar
Default gear box
i have a 400 renagade , i was told it is a copy of the 350 raptor, it went well but i gave it a hammering and it started to jump out of gear , mainly 2nd and 3rd. i had the gear box replaced . new gear cluster , selecter forks and selecter barrel. but it is still doing the same thing . it seems to be worse under load and when it gets hot. some times it jumps right out of gear and i have to put it back in and other times it will go back in when the revs die down . i hope some one can help me with this , as i would rather be riding it more than fixing it . . . . . [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 9, 2008 | 11:57 AM
scrambler400enoge's Avatar
Shapeshifter Rider
Default gear box
Ok you need to clear some stuff up There is no such thing as a 400 renagade.When you say renagade do you mean The can am and if so it's no copy of a 350 raptor.Were the clutch components replaced? sounds like a shifting problem you might have,the plates could be worn out.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
